I can’t add the IBS-TH3 to the Inkbird Pro app. It does not appear on the list of available devices. I have the ITC-308 wifi, the IHC-200 wifi, the IBS-M1 and the IBS-TH1 all working with the app, but i can’t seem to add or use the IBS-TH3. I am using this whole setup to manage and monitor a greenhouse. If someone has an idea on how i can get this sensor to work with the app, it would be greatly appreciated. Thanks
IBS-TH3 only supports INKBIRD app, it is not support Inkbird Pro app. Please use INKBIRD app.
I had the same problem with the TH3 and moved to the INKBIRD app. I liked the interface on the Inkbird Pro app better – it showed temps and humidity values on the icons of the devices in the Home and Room views. Can you add similar functionality to the INKBIRD app?
I will send it to the engineers as a suggestion.
The IBS-TH3 feature update supports the widget. It is currently available for Android.
And the IOS will be completed this month.
Awesome, please keep me updated on this!
Yes, please keep me updated, as well. Thanks much!
great! I also consider investing in a TH3
