The IBS-TH3 documentation I can find says it samples every 10 seconds but records at a fastest rate of 10 minutes.
Can someone confirm that the fastest this sensor can record/display data in the app is once every 10 minutes?
Thank you
Thank you
The IBS-TH3 updates the temperature and humidity readings every 10 seconds. Its data logging interval minimum setting is 10 minutes, which means that temperature and humidity readings can be recorded every 10 minutes.
