I have just purchased the Wifi bridge (IBS-M1) and two Temperature sensors (IBS-TH2).
Everything connects, but the M1 loses connection to the sensors after about 10-30 mins. For testing purposes I have one of the sensors only about 45cm from the M1. Changing the interval time on the sensors via InkBird Pro (eg 10min v 1min) seems to have no impact on the time till it drops out.
At the time of the dropout the blue light for that channel on the M1 goes off and I get a Notification in the InkBird Pro App that the Sensor is disconnected.
While in the dropped connection state
Engbird can still connect to the sensors.
InkBird Pro can still connect to the M1, and the M1 reports as Online and Connected
To restore connectivity I need to re-pair the Sensor (TH2) with the M1. ie place the TH2 close to the M1 and replace the batter.
Restarting the M1, or the TH2 on their own (at a distance) is insufficient.
IBS-M1 details
WiFi Firm Version: 3.1.4
MCU Module: 1.0.2
IBS-TH2
Version (per Engbird): 2.1.0
Any suggestions on how to investigate and resolve this issue?
Do you mean two temperature sensors (IBS-TH2) have the same problem?
Is there possible to provide a screenshot of the inkbird pro - IBS-M1 - sensor readings?
Because there are two versions of IBS-M1, the first generation of IBS-M1 has a compatibility problem with IBS-TH2. We do not recommend using them together.
IBS-M1 second generation has fixed this problem, it is compatible with IBS-TH2.
I am not sure if you bought the IBS-M1 first generation.
According to this screenshot, it is the first generation of IBS-M1. It is not compatible with IBS-TH2.
Please contact the seller to return it and purchase the IBS-M1 second generation.
