Double checking that my ITC-306a is set up correctly
a few months ago, I set up my then-new Inkbird using advice from Ai, and it’s been working well so far. But only now I’m realizing that the way it is set up may be limiting the lifespan of my heater, because I was advised (I think that part didn’t come from Ai) to set the heater temp above the temperature limit, and because I heard that more heating cycles limit the lifespan of the heater. So, my question is, could y’all please help me double check that it’s set up right? Ty.
P.S. I don’t have the right Wi-Fi to connect to the Inkbird with the app.
Perhaps you could provide more details on the specific functionality you wish to achieve, as well as your current settings for the ITC-306A?
If the heater has a built-in temperature controller, and the heater temperature is set higher than the target temperature of the ITC-306A, the temperature control will be performed by the ITC-306A.
Conversely, if you set the heater’s thermostat to a temperature lower than the target temperature on the ITC-306A, the heater’s own built-in thermostat will handle the temperature control, while the ITC-306A can serve as an over-temperature safety safeguard.
If the heater is switched on and off frequently, its lifespan may be shortened.
