I use my ITC-308 WiFi for a fermentation chamber, but when not fermenting I’m using the cooling device (fridge) for it’s original purpose, i.e. without the heating.
Currently that means I need to either:
- Unplug everything and plug the fridge into a “normal” socket
- Set the temperature lower than the fridge will be, and also lower the low temp alarm. Inkbird is constantly “cooling”
I think it would be a nice improvement if the app had a function to disable the thermostat/temp control functionality and allow manual control of the sockets in that mode.
