I like to use the +12VDC from E2RH (terminal 4 and 5) to switch 3 solid state relays (SSR-40DA) connected to E2RH Timer A relay (terminal 7 and 8). The SSR relays will send 120VAC output to heaters when switched. Each relay draws about 7mA for switching. Is this possible and do you have a wiring diagram?
Related topics
| Topic | Replies | Views | Activity | |
| ITC-100 relay control | 1 | 318 | August 25, 2022 | |
| Using ITC-100RH to control SSR | 2 | 282 | June 13, 2024 | |
| Q: What is the difference between ITC-100VH (ITC-106VH)/ ITC-100VL (ITC-106VL)/ ITC-100RH (ITC-106RH)/ ITC-100RL (ITC-106RL)? | 0 | 971 | October 15, 2021 | |
| Is the (12V) ITC-1000F 10A switched circuit an actual isolated relay contact or electronic switch? | 0 | 181 | August 17, 2023 | |
| Q: Can ITC-106VH connect multiple heating elements? | 3 | 873 | December 15, 2023 |
