A: If it is within the power range, it is ok.
I have an ITC-106VH and SSR-40 DA set up with a single 380W heater between the SSR Pin-1 and the 120VAC Load line. Can I simply wire a second 380W heater in parallel with the first? Or do I need to rewire for a second heater as shown in the image above? Thanks in advance for any help with this.
It’s ok to wire the heaters according to your wiring diagram.
Excellent, Thanks Tania.
Cheers,
Ralph
