Anyone run 2 or more Inkbird Wi-Fi Gateway, IBS-M1 Wi-Fi Bridges
Anyone run 2 or more Inkbird Wi-Fi Gateway, IBS-M1 Wi-Fi Bridges. Using 1 at work with 8 sensors. A couple sensors in the far fridges that disconnect from time to time. They have brick walls between them and the Gateway. I want to run 2 gateways. 1 in the front 1 in the back. Is this possible? Or will it be hard to have the proper sensors connect to the proper gateway. Thanks very much
2 IBS-M1 gateways can be connected to the same sensor at the same time.
