Hi everyone,
Nowhere I easily found the sensor length on the site. Any chance someone can tell me ?
Claude.
Hi everyone,
Claude.
IBS-TH2 has a built-in probe, it has no external probe, so it has no probe length.
Thanks Tania. Perhaps I should have asked a different question. I want to install an hygrometer and thermometer probe or device in a concrete bunker (wine and vegetable cellar) with the reading device located outside the bunker on the upper floor. This is why I originally asked if there was a wired probe as I am unsure if the bluetooth waves will pass through the concrete.
The Bluetooth signal is affected by obstacles such as walls/doors/windows. It may not pass through concrete very well.
If you need an external probe, how about the IBS-TH2 PLUS + temperature and humidity probe? It has about 2 meters of probe + probe wire.
Details: https://www.amazon.com/dp/B095W39L4M
Or ITH-20R + IBS-M1 gateway? ITH-20R uses RF technology and it will have a signal range farther than Bluetooth. the ITH-20R-O transmitter can connect to the IBS-M1 gateway via RF and the IBS-M1 gateway can connect to phone app via internet available 2.4GHz wifi (not sure if the 2.4GHz wifi is covered where you plan to install). After successful connection, the phone can realize remote view data.
ITH-20R details: https://www.amazon.com/dp/B07SPV8XXP
IBS-M1 details: https://www.amazon.com/dp/B08352XHWV
These seem like very good options. Thanks so much for responding.
Thanks Tania. I appreciate your answers.
1- So, with IBS-TH2 PLUS, can it connect to an application via an IBS-M1 gateway to a remote application ?
2- for the probes, can I use an extension since the length needed is over 2 meters and if so, what type or size of the jack is required ?
3- For the ITH-20R, can it tolerate 90% or more humidity levels ?
I could see both options being good ones if the answers are positives.
Claude
thanks for your responses. I appreciate it.
Hi Tania.
One more question: How many extra sensors can I connect to the ITH-20R and what part is it from the website so I can order them ?
Thanks again Claude.
If you mean ITH-20R-I receiver, it can connect up to 3 ITH-20R-O transmitter.
Link of ITH-20R-O transmitter:
Hi Tania,
About extending the probe, I tested a 10 feet cable and it work perfectly.
The readings are exactly the same with or without the extension cable.
The cable I bought is an extension cable used for car rear camera.
Here is the description at Amazon.ca:
Pixelman 2.5mm Male to Female Backup Camera Extension Cable, 10ft Rear View Extension Cord for Dash Cam Mirror.
In my case, it solve the distance problem.
Hope it’s useful for someone.
