I own a IIC 600WIFI
if i use a master valve normally close 24v, will it open at the start of zone 1 and close at the end of zone 6?
Is it so, or i m wronging?
Thanx
The master valve is synchronised with the opening or closing of zones. If zones are started sequentially, the master valve will open at the start of zone 1 and close at the end of zone 6.
Besides, please note that the IIC-600-WIFI only supports 24VAC, 1A water valves. It doesn’t support 24VDC.
