ITC-308 Wifi Shows Wrong Freezer Temp; Keeps Cooling
My ITC-308 is on a freezer. It’s supposed to cool down to 35. It will not stop cooling, so the freezer went down to around zero. The display says the temperature inside the freezer is about 48, which is obviously wrong. What’s wrong? Is this thing ruined?
Do you mean when the temperature reaches TS (SV), the cooling indicator of ITC-308 is off, but the cooling outlet is still on?
Could you please let me know the voltage and watt of the freezer?
