Is this normal? ICS-027BW
Hi all, I’m Cadenza, 36M from the Netherlands, and I own a Large Kamado.
I recently bought a ICS-027BW, and today I’m using it for the first long session.
I set it up to get to 115C, and checked it after a while to see it at about 75C, and the fan at 100%.
I walked outside, to check, because I expected it to have hit the 115 for a while now, and I saw the temp suddenly go to 135 on the app, and the fan to 0%.
I’ve seen more issues (older posts) with this model, but they dont seem similar. I suspect more of a connection loss? is this normal behavior? I was home all the time, and the phone just lay on the counter.
The image below shows the temp increase of >60C in an instant.
I see from the screenshot that the ISC-027BW uses a Wi-Fi connection. The stability of a Wi-Fi connection depends on the distance to the router; obstacles such as doors, walls, or windows between the device and the router can affect the Wi-Fi signal. Could you check if this might be the cause?
If the device were using a Bluetooth connection, the stability would instead depend on the placement of your mobile phone.
Additionally, please verify the accuracy of the probe readings—for example, by placing the probe in 100°C boiling water (please note that the probe cable is not waterproof)—to rule out any issues caused by unstable probe readings.
