Does Inkbird provided an API for the IIC-600-WIFI/IIC-800-WIFI?
This would be a great feature for the product as it will open it up for many customers that wish to integrate into larger home system monitoring and control system.
There must be something as there is Inkbird phone APPs that communicate already.
I prefer not having to attempt to reverse engineer the communication protocol/method.
I really wish they would release the Api for the inkbird as I am part of a huge group that uses them for many temperature control projects both hot and cold. It would definitely increase the use as many more people can integrated with the Hardware. I think not releasing it will move our projects and applications to different hardware.
I believe the devices are using the Tuya platform but it seems to use a highly customised integration. I tried registering my IIC-800-WIFI using the SmartLife app for the Tuya platform and it did register but the interface in Smartlife was not very usable.
I agree with others in this thread, an API would be a big selling point for these controllers. Once everyone found out that they could be integrated into HomeAssistant and other automation systems, they would sell like hotcakes.
Yes it would be great to be able to integrate into home assistant or the like, this would allow the use of multiple esp32 based moisture sensors to determine when to disable watering schedules. Otherwise I find the IIC-600 a great system
Unfortunately I did not check before buying the product … in 2026 is hard to believe there is a product not open to Home Assistant local or cloud integration. We have multiple sensors and conditions that can be used to control garden watering that are not directly compatible with this product: soil humidity for different zones, weather station, weather forecast efc.
Considering the above I think I’ll return the product and buy a product that provides an api or direct integration with Home Assistant.
I will also create a dedicated message in all Home Assistant forums and groups to be aware of this incompatibility before investing in this product.
