IIC-800-WIFI Local Weather Rain Skip
I recently purchased the IIC-800-WIFI thinking it could rainskip based on the app being aware of my local weather.
I bought the IIC-800-WIFI because physically it’s one of the nicest looking irrigation controllers on the market.
After re-reading the manual I see that it only works with a rain sensor, and can’t make decisions based on local forecast. Why? There are WiFi controllers half the price on Aliexpress that have rainskip based on local weather.
Why does the app show you the local weather, but not have the option to skip watering on rainy days?
I’m now looking at buying a different controller because I don’t want to have a rain sensor :frowning:
My question:
  • Is app-controlled rainskip on the development team roadmap for the IIC-800-WIFI? It makes it a more attractive WiFi controller in the market.
You can absolutely make a makeshift rain skip without a rain sensor. Under the section Smart->Automation, you can manually set the rain sensor by:
If Weather → Rainy
Then Rain Sensor Off (or maybe on, I have to test this when I get everything setup)
Don’t forget to do an opposite rule when it’s not raining. I do seasonal adjustments based on weather too in a fairly complex set of rules. I have a greenhouse and want more water when it’s hot and sunny. Less when it’s gloomy and rainy.
I know this was a year ago, but just seen the response.
I spent quite some time trying to get the rules based rain sensor functionality working at the time of the post, but never had any luck.
I’ve just had another look in the app now, and I’m fairly certain there’s actually new functionality allowing this form of automation. I don’t recall being able to set the state of the rain sensor previously.
Actually - I think I’m correct, as Inkbird did respond to this question to me but in another thread at the time:
So it’s nice to see this functionality is now there. I’m not using it however as I ended up just buying a rain sensor instead. But it’s useful to know for others…
What rain sensor did you get?
This one. Although the price seems to be about double from when I purchased.
I just chopped the end off and wired per the wiring diagram.
Seems to work well.
I also painted it black to match my roof and hid it in the guttering.
See attached.
