I purchased the ISC-027BW thinking I could use it to introduce cool outside air into my stand up smoker to DECREASE the temperature when the gas burner temperature got too hot, in order to use the PID to keep the internal temperature down to 225F. However, it looks like this unit is designed to INCREASE the temperature of the smoker by blowing air over the hot coals in a coal smoker. That is not my situation.
I do not believe the unit can be reversed to my needs, where it only works when the temperature EXCEEDS 225F. Is that correct?
If so, is there another unit you make that can be programmed to begin working when the smoker exceeds 225, and perhaps would turn off at 230 or 235 degrees?
