Continuous Heating Warning ITC-306A wifi
Hello community. For the past several days my aquarium temp controller has been going off with the continuous heating warning. It has been going off early mornings, between 5-6 am for 4 days in a row. The unit never goes off during the day or evening. Can anybody out there think of a cause for this? Thank you
CT (continuous heating time alarm) is designed to remind that the temperature cannot be heated to the target temperature within the time range set by CT.
Please check if the heater power is too low or the ambient temperature is too low, causing the temperature to fail to reach the target temperature within the set CT time range.
