308 calibrating
Just got 308 but it’s showing 25C but temperature according to mercury thermometer showing 18C(it feels around 18C and def not 25C)how do I CA calibrate to lower setting…
Seems easy to set 308 to higher temperature,should I cool 308 by putting in fridge and wait till its same as mercury thermometer then set it or is there a better way.
Perhaps you could test it by putting it in a 0C/ 32F ice-water mixture? But make sure it’s measured for enough time.
About temperature calibration (CA):
When there is a deviation between the read temperature (PV) and the actual temperature, please adjust it through the calibration function.
For example, the reading temperature (PV) is 3 degrees higher than the current temperature, please set CA=-3. The reading temperature is 2 degrees lower than the current temperature, please set CA=2.
