Hello guys,
I have a rain sensor from my old system (all Hunter), I have remove my old control unit X-core and replace that with IIC-600.
It’s rain sensor “Hunter Mini>clik” compatible with IIC-600?
It’s two wires sensor.
Thank you in advance
If the rain sensor supports 24VAC irrigation controller, it is compatible.
Please make sure the wiring is correct.
Thank you, I will try to connect then.
regards
Hello, I have the same rain sensor (Hunter) and wired it. However, I can not see on the app any information when the rain sensor is active or not. Last night it started raining and the app did not indicate this
Sorry, it does not have a function to display the status of the rain sensor currently. It will be upgraded in the future.
Is rain sensor supported in the app yet? So I can follow possible rains during night and how much that poor down?
Hello
Are there updates on this? When the rain sensor detects water, does the app show this somehow? It still shows the next scheduled time even after heavy rain. The wiring is correct.
It’s 3 years now I use it and I’m wondering the same question with this very nice product.
Always worked like a charm, never had issues.
But… there is still no possibilities to know if the rain sensor has been ON and used or not in the data logs of the app.
It just shows that it activated flow at the setup time and day but… you can’t see if the sensor was ON and in reality no water flow was open.
I saw a moderator said it would be on a next update.
is it still going on and is there a hope we can see this?
I love this product, but the software is not very good, not intuitive.
Thanks to help us with this request ![]()
Cheers from France
Sorry
, after discussions with the engineers, they found that this feature involves many aspects, and the difficulty of adjustments is higher than expected. It may be implemented in future models
Hello, I have and have just connected INKBIRD IIC-600 with a rain sensor.
After the rain the controller stopped watering. The break has been going on for 5 days now.
