I’m trying to set it up in conjunction with a light on a timer. The timer is set 12 on and 12 off from 09:30-21:30, the light timer has been checked and works properly. When I press the up arrow on the ink bird to see how much is left in the stage it says 1-3 hours remaining and the light has changed stages. This number increases every 24 hours. They will not stay remotely synced.
Settings:
HD2
CD2
AH 212
AL -40
PT 0
CA 0.0
CF F
TR1
UT H
nd 940
AT 1
Stt 2
SST 1
SO1 79
HO1 12
U01 n
S02 70
HO2 12
U02 n
A: Please note that if the controller has entered the setting mode, the time will be reset if you manually saved or automatically exit the setting mode.
So if you want to check settings during the running time, the time will be changed to 12 and restart.
