ITC 106VH, thermocouple calibration
Instructions say: “6.23 …the temperature need to be calibrated for there will be deviation…”
How do we perform corrections, if needed, to the measured value?
Is this the Input Sensing > Calibration Unit/Setting Range?
And WHAT is Digital Filtering?
Thanks…
If you want to change the calibration value, please set it through the SC function.
For example, if the probe reading is 1 degree higher than the actual value, please set SC= -1.
If the probe reading is 2 degrees lower than the actual value, please set SC=2.
For more information about Digital Filtering, please refer to:
