IIC-800 WIFI - Setup storage without network connection
How can I store date and time setup while the equinpment is not connected to a network.
Here follows what I’m experiencing:
  • I unpacked the device in an area WITHOUT any WiFi connection (couldn’t use the app);
  • setup and saved date and time following the manual procedure;
  • date and time showed correctly on the display;
  • unplugged the power supply;
  • plugged power supply back;
  • date and time setup went lost (display showed the default date and time).
When I was able to reach a WiFi served area, I connected the device to the local network and everything was automatically setup and maintained even after unplugging the power supply.
The issue is that I’m going to use the device in a scenario without any network available and cannot run the risk to lose the stored data. If I can’t solve this problem, I’m afraid I’ll have return the controller back.
I contacted Support and they advised that you have been contacted and are in the after sales process.
Please check the email message.
