C236T Automations and Scenes not working
Dear Inkbird,
I bought a C236T WiFi temperature controller unit. My plan was to use it during the day at 50C (45-55C range) and at night at 30C (25-35C range). The built-in functions don’t allow me to do that but I had seen the ITC-308 automation functions and I was expecting I would be able to do it through my own sequence of automations.
C236T cannot be added in automations nor can it be seen by Google assistant or IFTTT. I need a greater than 13A controller, so ITC-308 is not an option for me.
Can you please help me sort this out? I will have to return the unit if it can’t do the function I bought it for.
Best wishes,
Christos
Sorry, C236T does not support Google assistant or IFTTT at the moment. Automation is an additional extension of the INKBIRD app and is still under development. C236T only supports the original function, which means it can set a temperature range + timer function. It cannot set two different temperature ranges.
