IBS-M2S-B Gateway Wi-Fi Connection Failure
Dear INKBIRD Technical Support,
I recently purchased an IBS-M2S-B gateway with three ITH-11-B temperature and humidity sensors.
I am unable to complete the gateway’s Wi-Fi setup using the INKBIRD app.
Problem description:
The app successfully detects the gateway and starts the Wi-Fi configuration process. However, after displaying the message “Device connecting to network”, the process ends with “Connection failed”.
The gateway’s green LED continues blinking slowly (approximately once every 1–2 seconds).
Troubleshooting already performed:
1. Confirmed that the Wi-Fi network operates at 2.4 GHz.
2. Verified that the Wi-Fi signal is excellent.
3. Confirmed that the network uses WPA/WPA2-Personal security.
4. Disabled mobile data on the phone running the INKBIRD app.
5. Confirmed that the app has location permissions enabled.
6. Pressed and held the gateway’s Wi-Fi button for approximately 5 seconds. The gateway emitted a beep, but the green LED continued blinking slowly.
7. Attempted to configure the gateway using a second internet connection provided by another smartphone’s mobile hotspot. The connection failure persisted.
I would appreciate your assistance with the following questions:
1. What does a slowly blinking green LED indicate on the IBS-M2S-B?
2. Is there an alternative pairing procedure, such as AP mode, for this specific model?
3. Does the gateway require access to particular servers, ports, or DNS services during registration?
4. Could regional network restrictions interfere with device registration? Would using a VPN help in any circumstances?
5. Are there additional diagnostic steps to determine whether the problem is related to the gateway hardware, firmware, or app?
The equipment is intended for environmental monitoring and data logging in a research project. Reliable operation and data continuity are important for our application.
Thank you for your assistance.
Best regards
Perhaps you could check your phone settings to ensure that all permissions for the INKBIRD app are enabled. If the permissions for the INKBIRD app are not granted, it could lead to connection failures. Also, make sure that both Bluetooth and location services are turned on on your phone.
A slowly flashing green LED on the IBS-M2S-B indicates that it is waiting for a network connection.
The IBS-M2S-B supports only one connection method.
Please refer to this post. If you are using a specialized network—such as a campus network or a connection with an active VPN—the device may fail to connect:
You can use a mobile hotspot to test whether the issue stems from the device itself or your router settings. Please note that if “Phone A” is providing the hotspot, “Phone B” must connect to that specific hotspot; ensure that it does not automatically switch back to a standard Wi-Fi network.
